what are the advantages for three phase power supply than single phase power supply ?
magdyfayad
Aug 2007
cairo
245
what are the advantages for three phase power supply than single phase power supply ??
i have a machine contain electronic cards and three phase power supply from SIEMENS SITOP 40 24 VDC , this power supply was deffected
i put a single phase power supply 24 VDC , the machine worked but with some problems
i brought three phase transformer , three phase rectifer , and a capacitor , then the machine worked well
so , what are the advantages for three phase power supply than single phase power supply ??
i know the ripple is less for three phase power supply , are there anything else ?
thanks
thanks
You've already mentioned the advantages:
No transformer, rectifiers and all the other **** is needed with a 3 phase power supply. Plus saves time with wiring and panel space.
You can do away with the single phase or 3-phase transformer. This is a significant saving and also means less heat generated in the panel.
What were the problems ?
In the old days with a simple rectifier bridge and capacitor banks it was so. Today all PSUs are regulated.
I think single phase rectifer it work without any problem if you check the current required to you power supply card, where not only voltage 24 vdc enugh but the current also .
if you want to desgin power supply circuit most be know the power required and voltage.
Thank you
thanks all
the problem occured with single phase power supply is at an electronic card which its output is reset during work
Yes that I mean, if the power supply (voltage and current) not in the same rate of power card the machine will reset or stop but when you use three phase power supply the current of the circuit become more the the current in singel phase by root squar 3.
meany thanks
Hello world. This is my first post here. My question: Should I upgrade from DirectSOFT05 (5.3) to the current version? My project is to build a...
1,938
So Ladder is easy to read graphically, most everything can be coded in ladder, and it represents wiring diagrams the closest. SCL and ST are good...
1,725
I need Pros and Cons of WinCC(TIA), WinCC flexible and Intouch,which will be using with Siemens S7 1200 Controller.. It will be used for...
2,306
hey guys, the company I work for has decided they want to update our PLC5 machines to Controllogix with ethernet communication so they can monitor...
2,597
hey guys! i was wondering why did profibus adopted the master-slave exchange of data? it is the most efficient way? For example if i had a...
5,138
