TP700 Comfort... Remote Control
userxyz
May 2002
any
2,768
I have a TP700 Comfort that logs csv's on a USB-stick via scripting.
I have also check marked the SmartServer.
With a PC and browser I can login and get the daily created csv files via the file browser from the connected USB stick.
The remote control does not work.
I have installed the last version of Java runtime and I'm running Win 10.
I have trief IE, Edge and Chrome...
In the older panels, I needed to activate the SmartAcces if I remember well, but cannot find such check-mark, so I guess the smartserver is the right check mark.
I am in TIA v15.1... I don't think a license is needed.
What could be the issue ?
When I browse to the IP adress of the panel, I can login, when I click on Remote control I can see that it tries to doe things, but I get an empty page...
Any suggestions ?
Thanks,
Kind regards,
Combo
Yes, smartserver is the name for the feature now.
In the control panel of the TP700, there are some Internet Settings/web server settings you need to set. I don't have a panel in front of me to check, but at the minimum, you need to assign an administrative password. There are a ton of Remote Control settings, I think you need to also assign passwords for read only and read/write passwords.
Hi experts hope you are well. Would any one be able to tell if it is possible to pull data from a Delta V DCS and display it on a TP700 comfort...
471
Hello great friends. Please help me....what is the easiest way I can RESET a Siemens TP700 COMFORT HMI Touch panel, to its Default...
1,306
Hey guys, I am new to vb scripting in TIA and had a small query. I need to view certain data from HMI in excel. After running a certain script I...
2,636
Hi, expert: We got OEM machine with S7-300 and HMI TP700 comfort, we don't have PLC program for S7-300 and we don't have runtime file for TP700...
1,404
Hi, i need to filters alarms (if is possible) by using the report groups. Also, i need to aknowledge all alrms preset by pressed a graphics...
1,303
