Strange Behavior: 1746 OW16 (Allen Bradley SLC500 Module)
Russ
Jun 2002
Ohio.. Go Bucks!!!!
261
I have two output cards sitting next to each other in a rack:
1746-OW16
1746-OW16 (Octal)
output 13 in the first card triggers a solenoid. When output 15 (17 octal) on the 2nd card goes high, the output on the first card drops to zero volts.
When output 15 is low, output 13 works fairly well. The voltage looks normal (120VAC) most of the time, but sometimes still drops to 0.4VAC; however, when output 15 goes high, output 13 drops within a few cycles.
I found a spare output, and used that, but I'm not sure if I should just replace the card, or if there may be some underlying issue that I'm not seeing. It may also be a red herring,
Maybe it doesn't have anything to do with the card. Maybe there is something wrong with the wiring of the solenoids? Issue with the common wires or grounding? I would disconnect all wires from the outputs of the cards, force each output on from the PLC logic, then measure each output with a meter. (With nothing/no wires connected to the outputs.) This will help eliminate if it's a bad card or if it's caused by the solenoid wiring.
Hello all, I am facing an issue with my Commander SK that I cannot solve on my own, I am struggling on it since several days :confused: The...
1,033
I have a small system controlled by a Siemens S7-1200 PLC. I created a totalizer function block (TIA v17), where I'm counting total revolutions...
3,099
Hi, I'm experiencing a very strange issue with the functionality of an AOI after upgrading to firmware V32. Bit of background: CPU is a CLX...
3,290
Our CNC machine's spindle has a speed feedback encoder connected to it via a belt. The feedback rpm is displayed on the operator screen. When we...
2,175
I have one strange issue, I'm not experienced enough to understand. We have generated one FC for scaling and writing to analog outputs, which we...
6,559
