Mitsubishi Q series...24VDC power distribution for din rail...
Mas01
Oct 2020
Leicester, England
1,109
In our PLC, we've got a 24VDC (5 amp) power supply - it's a PULS cp5, which connects to a DIN rail. I need it to supply power to 8 x Druck pressure sensors.
I don't want to connect all 8 of the device wires into the power supply (in fact, it would be almost impossible to stuff all those wires into the power supply). Can anyone recommend a way to neatly distribute this power, so that each device has its own +24VDC and its own 0VDC terminal block? i.e. some sort of "busbars"...one for the +24VDC and another for the 0VDC. I think I have seen some sort of 'row of din connectors' which has a metal strip running from the first to the last terminal block, which might be a solution.
Sorry for the basic question, but I've not done this sort of thing before. Thanks
pick your poison for the most part.
AB - Siemens_- DINnector - etc etc
lots of brands to choose from. all sell the same basic stuff. heres some from automation direct that you could use.
These are basic, so use the terminology 'Terminal Block' 'Din Rail Terminals' and look for the matching busbar/jumpers that work with the type you pick.
Terminals -
https://www.automationdirect.com/ad...e-level_feed-through_terminal_blocks/dn-t12-a
Jumpers for these terminals -
https://www.automationdirect.com/ad...evel_terminal_blocks_-a-_accessories/dn-24j2y
Terminals -
I think something like that will do the trick.
Thanks!
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
36
In this sample programming, what does U4 mean? Any assistance would be greatly appreciated.
273
Hi, I have a project with a R04CPU, RD77GF16 and a RJ71PN92 modules. The cell is given to me to change the program since the previous integrator...
288
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,170
