Print from panel view plus
If I understand the op, he wants to print alarms.
the plc has a fault / alarm condition.
the panelview terminal then displays the fault / alarm.
he wants to print the fault / alarm.
Rutesh M Deshmukh, is this correct?
if it is, you still need to answer my questions posted earlier.
james
You can place a "DisplayPrint" button on the alarm screen. Connect a printer to the HMI USB port. See the PanelView Plus user manual for details.
Rutesh M Deshmukh,
the questions still remain.
what is the model # of the panelview terminal?
what is the model number of the plc?
we know what you want to do, but can your terminal and plc do what you want?
james
Is there any way to have a trigger in the PLC print a PV+ screen?
2,796
Hello Everybody, Has anyone used the Panel View Plus Print screen feature recently with a HP printer? I tried for the first time today. I read the...
2,260
si'm looking for a small,inexpensive, touchpanel HMI that can connect to a printer to print simple text reports. The HMI will read data from a...
2,214
Will someone please convert this logic to pdf?
127
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
381
