Migration Slc to compactlogix/contrologix
stu
Aug 2005
England
783
Hi all
We have quite a few Slc plc and as they are obsolete we would like to plan for the future and convert to compactlogix?
How easy is it to migrate
Can I get the same style modules so less moving about of wires
I have heard about a migrating software has anyone used it ?
Thanks stu
if you're allowed to attach one or two of your existing .RSS files, someone will probably come along soon and do a "translation/conversion/migration" for you ... then you can see for yourself what's involved ...
NOTE: you'll probably get quite a bit of advice that you should just "start from scratch" to gain all of the benefits of the newer features that are available - but if you just want at quick peek at what the code looks like after a conversion, then we can certainly help you out ... that might help you decide how to proceed ...
That's difficult to say. If you had asked me 20 years ago I'd said "everything around a migration is difficult, in fact, I don't know where to start". Today, my main concern is to know if all the new stuff can be installed on the same old cabinet.
There're similar styles modules, with the same number of channels, and even you can find that it's possible to substitute two SLC modules by one of CompactLogix. However, more important is to check if the electrical characteristics are the same or else you will have to make changes in the external devices. For example, 1746-IC16 module (16 Input 48 VDC) has no direct equivalent in CompactLogix, so if you want to keep the external sensors you have to look for an alternative solution (adding a Flex adapter + 1794-IC16 , going to ControlLogix + 1756-IC16).
Rockwell provides Integrated Architecture Builder (IAB), a software to help with the hardware decisions. You can read about IAB in the following article:
https://theautomationblog.com/what-is-integrated-architecture-builder/
I use the IAB version included in my Toolkit and the wizards are an incredible help when I have to evaluate a migration: just describe the old architecture and the software chooses the best configuration for the target platform.
Yes, there's a migration tool. As Ron said before, you can test the tool and then decides what path to follow. In my experience, automatic conversion tools are not perfect and just give you a point where to start.
In any case, you have to design your own protocol to audit the migrated application, i.e. you have to demonstrate that the migrated application works in the same way as the original did.
Finally, I recommend you to read this document from Rockwell about SLC to CompactLogix migration. Every migration's step is well described there:
http://literature.rockwellautomation.com/idc/groups/literature/documents/pp/migrat-pp004_-en-e.pdf
This SLC system has been partially upgraded with a CompactLogix 1769-L19ER processor. The I/O of the SLC was left in place and connected to the...
1,362
I have searched AB knowledge base and can not find the answer to my question, maybe I forgotten how to read. I have a project to change 4- SLC...
3,248
Hello, Would like to hear your thoughts regarding upgrading a SLC-based system. Current configuration has SLC1747-L532 (2 racks, DIO only)...
1,665
Hi, I am using SLC 5/04 CPU (CAT# 1747-L542) with 1746 series I/O cards. I would like to replace only 5/04 CPU card with control / compact logix...
5,394
I'm currently working on a project to upgrade all of our 1747-L30Cs (SLC 500 fixed hardware) to Micrologix. I know these are both programmed in RS...
5,639
