Contradiction on Rockwell instruction
LucaPLC
Jun 2017
Home
Hi guys,
I'm working on AB code but I'm in trouble with the specifics on the MAPC command and his behaviour with the Execution Schedule parameter.
Please confirm or "fix" my idea:
(The Execution Mode is always = Continuous)
- Immediate with Master Reference = Actual --> The camming starts immediately when the MAPC is enabled (Master Lock Position ignored);
- Immediate with Master Reference = Command --> The camming starts when the master axis reach the Master Lock Position;
- Pending with Master Reference = Actual --> the camming starts immediately when the pending cam ends independently of the master axis position (Master Lock Position ignored);
- Pending with Master Reference = Command --> when the pending cam ends, the slave axis continues in velocity until the master axis reach the Master Lock Position (where the new camming starts).
I hope someone can resolve my dubts.
Thanks.
Luca
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
151
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
110
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
127
I'm working with a project that contains some routines in ST but mostly in ladder. Am I correct in assuming this 'rung': DB1001DO._01AV55_OPEN :=...
113
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
75
