CarloLuongo
I'm developing a routine to detect and clear a watchdog major fault in a ContolLogix PLC. The software has three tasks and six programs.
According to the "Logix 5000 Controllers Major, Minor, and I/O Faults - Programming Manual" I've created a Controller Fault Handler (for major foult type =6, code = 1 => watchdog) in order to detect and clear the major fault.
The example of the manual uses the keyword THIS in order to address the program object of the GSV/SSV instructions accessing to the fault record of the current program.
I've done the same (see attachment) but my fault handler Routine is part og the FaultHandlerProgram in the ControllerFaultHandler folder so, which PROGRAM is THIS if a watchdog major fault occurs? Is this the correct way or I've to specify the name of each program?
Thanks a lot
Carlo L.
Thanks a lot
Carlo L.
