ac and dc wiring together
MNJ96
May 2005
Salem, Oregon
50
guys
i have a control panel that is using 2.5 inch wire duct . the components that were purchased and specified and the available panel space . the ac and dc wiring will have to be in the same duct and run parrell to each other any suggestions
General rule of thumb is to seperate the potential differences by several means.(cross at 90's), do not run parallel AC and DC, etc. But in reality, you will find AC and DC mixed up all over in most panels that I have been in. The only thing that saves you is the correct colour code that your country and laws enforce.
There are suppliers that provide duct isolators, such as Panduit for one,
First, I make a disctinction between DC discrete I/O wiring and DC analog wiring. The analog is much more sensitive to EMI/RFI from the AC wiring. We have even had contractors run DC discrete and AC wiring in the same conduit and not experienced any problems.
We usually run two wire ducts side by side, one for AC and one for DC/Analog. We use a single cover over both. This is good practice, but in point of fact I'm guessing the incremental protection and noise reduction is minimal. After all, there is only fractions of an inch separating the terminal blocks on the PLC I/O cards!
If it is only control wiring there should not be an issue. Even small DOL starter loads and soft starters up to 45 kW do not cause me a problem.
We have only had problems with machines where digital lines to counters/plcs (from encoders/ photosensors) have been run alongside inverter outputs to a motor. This creates major havoc with counting systems!
It will with any digital lines if they're run together long enough.
AS A RULE--VFD wiring should not be run with any voltages less than 120. On our conveyor systems we run separate pipes for control and motor wiring.
Posted this to Reddit with little success, so I figured I would share it here as well. Very new to PLCs, but figured I would give it a shot to...
110
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
73
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS...
128
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
105
Hello I wanted to ask some questions about the G120C drive and the protection for it. I want to control a pump, with the motor rating of 5.5 kW...
193
