PanelView Plus communication loss if Flex I/O is connected with PLC
toont
Sep 2014
Den Bosch
56
Hi all!
Am having a strange problem with communication between a PanelView Plus 1500 ethernet and PLC-5 40D revision B.
They are connected as follows:
PLC RIO -> RIO to Ethernet converter -> PanelView Plus Ethernet.
PLC racks 2 and 3 are used for Flex I/O, rack 6 for RIO signal to converter. All are using channel 1B.
- When online with one or both Flex I/O racks connected there is a loss of communication once every few seconds, seemingly irregular intervals. This happens regardless of baudrate, rack order, RIO cable connection order (flex1/flex2/converter or converter/flex1/flex2) and RIO cable length short (2 meters) or long (~100 meters).
- When online with no Flex I/O connected there is no communication loss between PLC and PanelView Plus.
The converter configuration was double checked and these devices are working fine in several other setups using Flex I/O, PLC-5 and PanelView Plus. The converter is nog showing/logging any communication errors.
Can the Flex I/O somehow interfere with the RIO comms to the converter?
Unfortunately not, but since then a few new firmware versions of the RIO-Ethernet converter have been released with communication bug fixes, make sure you have the latest version.
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
667
I have a CompactLogix 5069-L320ER (has 2 comm ports) I have a Panelview Plus 7, Do I have to install a Ethernet switch? Can I connect directly...
1,120
Good afternoon, I'm having some HMI communication issues with FactoryTalk View ME. I'm trying to make an update to an existing program that has...
2,503
Hi, We have around 10 PV Plus HMI connected to CLX via ethernet IP-CAT6 cable it was working in good condition for few years but now there is...
1,727
Hello, I am currently installing a PLC control panel and due to space constraints, we will need to install the Panelview 600 HMI separate...
3,367
