kentuckytech
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this possible scenario. I am currently setting up 4 pumps with identical Powerflex 525s and I am setting up a Stratix 5700 6 port managed switch for communications. I have set up ports 3-6 using DHCP persistence so that in the event of a drive failure the mechanic just wires up the new drive and the stratix will assign the IP address and the PLC will download the parameters. I have successively set this up on my test stand and it does function properly. While playing around with the equipment I swapped 2 ethernet cables in ports 3 (pump 1) and port 4 (pump 2) and the drives lost communication and then re-established communication and continued to run their respected pump. The issue I found was as soon as the drives had a power failure and then powered back up they received the IP address of the port I swapped them to, thus pump 1 just became pump 2 and pump 2 became pump 1. The reason I bring this up is because we have mechanics that while troubleshooting a pump or motor issue sometimes get it in their head it might be a communications issue and they will swap ethernet cables on the switch thinking the ethernet port contacts could be dirty causing the issue. Doing this wouldn't cause an issue until some time later if the power cycles to the drive and then long after the mechanic that did it has gone home and it happens on a different shift the PLC is now running the wrong pump if it tells pump 1 to run. This scenario isn't a great deal with my application but I could imagine some scenario where this could be a safety issue. I hope I explained this clearly enough. My thoughts are if the drive parameter C128 is set to 2 (BOOTP) like it is using DHCP persistence, the drive should dump the IP address if communication fails so that when it is re-established the IP address of the swapped port would be assigned at that time instead of after the drive power is cycled. If this was the case the mechanic that swapped the cables would most likely see the issue he created and could correct it. Yes, i know the mechanics should know not to swap the cables but I know what happens here at my plant with different mechanics coming and going. Anyways what are you guys thoughts on this?
