Op15 Com Text
Dec 2003
english living in france
Hi Everybody,
We have just recieved in our company a small assembly machine, and the text is in German on the OP15, I need to translate this into French but I have no way to communicate with this OP,
I have phoned siemens who informed me that they have stopped issuing copies of COM TEXT since 1994.
Does any body out there have a copy of this programe or tell me of another means of setting up a com link to edit the text.
Thank you all in advance.
Kevin Churchill.
Kevin,
COM TEXT is an 'add on' program to STEP 5 ...I take it you already have access to a PC/PG running this software and the appropriate connection cable?
Yo Kevin,
I still have a copy of COROS COM TEXT v3.10 (09.07.96): It consists of 3 floppy disks. But, as krk already mentioned, it's add on software. I never tried to run it without Step5. Back then, I installed it on a Windows98 laptop, which had Step5 v3.0 already installed. What I do remember is that the hard drive had to be FAT (so not FAT32 or NTFS) and I had to start up in DOS mode to make it run properly.
You will also need a serial programming cable; buy it or build it yourself (check layout in attachment).
If you're interested I can send you the 3 (zipped) files, just send me your e-mail address.
I too have COM Text - but be warned , it is not an easy install - you may well be better getting a cheap harddrive than trying to install on an XP/2K machine . It also uses LHA de-archiver which is problematic with XP
I wouldn't normally be free with offering stuff like this , but even Siemens Automation don't have running copies of this stuff (but then they are still on S7 5.3 .....)
I have the English documentation for comtext in PDF if anyone is interested.You may need it Kevin if you are going to redo in English. Comtext is not what I would call straight forward. Send your e-mail to [email protected] and I will send you a link so that you can download it straight from my computer. (it's to large for e-mail)
Hi Pertti,
Just tried to send you the zipped files, but apparently your mailbox size is too small:
Code:
<[email protected]>: message size 3360671 exceeds size limit 3145728 of server
If you do have a larger one, let me know and I'll try it once more...
Hi all,
Just for your information, im using Comtext on a Dell laptop running xp pro. All i did was copy the whole Comtext directory from a Siemens 720 PG to the Dell hard drive.
I just open Comtext through step 5. (very slow to open, but fine when its running)
I had to load an OP15 this week with a .O15 file, so i know its all working ok.
Im also running Com Profibus on this machine, again i just copied the relevant directory from the PG.
No istallation was required for either software package.
Cheers
I have an COROS OP15-C1 (6AV3515-1MA20-1AA0) that I would like to get an upload of the program. I don't know whether the project was written in...
2,188
Hi, I'm working on migrating S5 to S7 and I have a COROS OP15 HMi. I need to know the tags from the OP15. I would be great help if someone can...
1,699
Hello, I'd like to be able to command a S5-95U through both OP15 (HMI) and Ethernet. Have anyone ever seen anything like this before? I know...
2,329
i finished a new project by protool v.6 sp3 on win xp , i have S5 TTY Programming Cable when i connect to op 15 display transfer ready but when...
1,275
dears is there any SFC to handle the communication between OP15 display and S7 PLC? as i need to send and receive some data ( analog and digital...
1,434
