Siemens OP5 to OP15 to ProTool
seppoalanen
Jan 2003
Finland
1,132
Hi !
I have old OP5 panel and it's file ????????.o05 and old ComText dos-based editor.
I have to change OP5 panel to OP15 panel. With ComText I have done conversion from OP5 to OP15, so I have file for OP15 ????????.o15
Now, I like convert it for ProTool 6.0 ????????.pdb file.
I have not found help from Siemens sites, but if someone have done this before, please.hlp
Hello, Seppoalanen;
Siemens has a small application called Konvert that does what you require (ComText to Protool), although I am not sure if version 6.0 will accept the converted file. Guess you've got to try it to find out. It works with Win95, Win98 and Win NT.
To download it, go to the Siemens support webpage and search for Entry ID 2022013.
http://www4.ad.siemens.de/csinfo/li...nfo&wttree=productnodes&lang=en&objID=4000024
Hope this helps,
Daniel Chartier
Thanks Daniel !
I've tryed it, but 1'st it is very complicated to use in German language, and I did not found how it must work. Anyhow I re-wrote it by ProTool for OP7, because they had changed it in Supreme Court from OP15 to OP7.
br. Seppo
Good afternoon. I need the software Com Text. Can you passme? Thank you very much in advantage.
seppoalanen said:
Hi !
Dear Sir,
if you took this program ( com text ), could you send me a copy too? i really need this program to download the PLC program to Coros OP15 . i am in very hard situation now. i 'm waiting your reply as quick as possible. many thanks
Hi, We have installed Logo in one project. I want to connect Logo 230RC PLC with Coros OP5 HMI. Is there any possible way to connect them ...
1,705
hello, is there anyone who has "siemens coros OP5" manual in english? thanks
3,722
Hi Does anyone know what this error message means: "$115 PC restart running" I saw this message on a Siemens OP5 yesterday, the OP is connected...
2,290
I am working on a retrofit s5 project with 5 Siemens OP5 panels, and those OP5's firmware are all V1.03,they are all more than 7 years old,but...
5,236
Hi, I am new to the PLCs, I am more used to PCs and Micro controllers, but I got an S5-100U CPU103 with an OP5 panel that I have to get working...
19,462
