theColonel26
I just got an IFM AL1343 IO-Link master with Modbus TCP interface
From the manual this thing seems to have a Web Interface(http) for view its status.
According to the manual the IP for the Modbus TCP Ethernet interface is 192.168.1.250 so I sent my Laptop interface to 192.168.1.99. I try to ping it, get nothing, I try to go to the web interface http://192.168.1.250 times out. So ok maybe that interface literally only supports Modbus and no other protocal.
So there is an IoT Ethernet interface. The Manual says it is set to DHCP by default. I don't have a network available where I am at (hotel currently) where I have an ethernet connection availvble with a DHCP server.
The manual seems to indicated that if it can't get an address from a DHCP server then it will default to a random one in the 169.254.1.1 to 169.254.254.254 range. Make sense that is standard behavior for most interfaces with DHCP enabled.
Problem is that is 64,516 possible addresses. I tried running advanced IP Scanner but it took like 15 minutes just to scan the first 2,500.... That's like 6 hours if my mental math is correct to scan all of it.
Any Ideas?
Any Ideas?
