PLC on an Anilam M1400 CNC Control
talibozek
Mar 2005
Hello,
For starters, I have about 24 hours of PLC programming experience...but I have skills in other languages, C, C++, etc.
I'm trying to help my father out in connecting a HAAS rotary indexer to a CNC with an Anilam M1400 control. It's a relay connection to activate the indexer and the indexer control has a relay connection back to the Anilam to signal it cycle has completed.
I'm not sure what type/brand/model PLC is used in this control, but I can see the instruction set is very limited compared to some of the documentation that I've been reading online.
The problem that I am having is that I need to activate a relay for 500ms, then release. Here is a snippet of what I have to do this so far (that doesn't work)
LD T10
IF 5
RES HAAS_START
EDF 5
IF 10 ( M_CODE eq 10 )
SET HAAS_START
OUT TON10 .5
EDF 10
M10 is used to activate the indexer in the Anilam control software. Activating the relay works fine.
Now, all this TON10, T10 stuff, I found pieces of in some old PLC code I found in a pile of papers. I'm not even sure if T10 is associated with TON10.
Depending if I used an LD or an LDI, the control will either hang after an M10 instruction or the relay will cycle so quickly that the control will not detect the activation.
I'm hoping someone out there is familiar with this style. I haven't been able to find anything similiar to this online.
Thanks for your help,
-Tim
Yes, correct, it is PC Based. I was able to find a manual for the Anilam IPI, which helped me greatly.
Now I have a question about inputs and now a PLC reads the inputs.
The problem I think is that the indexer provides a 250ms pulse when it has completed its rotation. I think the PLC misses the pulse. Is there a way, without an external circuit, to make an input buffered so that the PLC will be able to catch that it's input has gone high since the last loop?
Yes, a internal timer or latch circuit can be used "catch" and/or "extend" the input.
Is the PLC in your situation a different piece of electronics or is it a piece of software running on the PC in combination with some I/O boards.
It's a physically separate module from the PC. You have to manually upload the code from the control to the PLC module.
I tried this piece of code without much luck...
#define HAAS_FIN X1
#define HAAS_START Y5
IF 10 ( MCODE EQ 10 )
LD HAAS_FIN
OTI HAAS_START
EDF 10
I understand this to be, "Activate HAAS_START until HAAS_FIN goes high or 30 seconds has elapsed"
This resulted in HAAS_START going high for ~30 seconds...even though I can see the X1 (HAAS_FIN) LED blink for 1/4 second.
Is this considered a catch or latch instruction?
thanks,
-Tim
#define HAAS_FIN X1
LD HAAS_FIN
OTI HAAS_START
EDF 10
thanks,
-Tim
No, a latch will hold the state until such time as its released. This sounds more like a timer; the input signal starts the timer and the timer's output will be set for as long as the timer is programmed to (in this case 30 seconds).
In "psuedo C" (its been a few languages ago)
#define input boolean
#define timer_preset 30
#define output boolean
#define timer integer
output = false
while (not input) do nothing {wait or input signal}
timer = 0
output = true
while (timer < timer_preset) do every second timer = timer + 1
output = false
Hello, I am a plc engineer and I have a job to do in the NIGERIA 25000 TON GRAIN SILOS STORAGE CONTROL PANEL. A problem where the panel is not...
120
GitHub Link: Open Industry Project This is a side project I've been working on for some time. The goal is to provide an open platform for...
125
Dear All, Currently i'm working with Endress Hauser flowmeter and AB PLC and try to integrate with 2 items. Flow meter spec using is Promass...
167
Can I connect two A-B Panel View 7 to a A-B PLC. Same graphics etc. One on the local control panel and the other Panel View 7 in a remote control...
65
Hello, I'm working with Studio 5000 and ME Station, and I'm trying to find a way to detect if the PC with the HMI is shut down or not. I've tried...
150
