Integrate Axis IP Camera feed into FactoryTalk Studio HMI Application
jmaty23
Mar 2009
New York
49
I am looking into the possibility of integrating an existing AXIS IP Camera feed into a FactoryTalk HMI Application. I have downloaded and installed the AXISMediaControl ActiveX control and loaded it into a Display.
I am currently having trouble filling in all of the parameters correctly on the Connections tab of the ActiveX properties screen to get the video to show on the HMI display.
I am wondering if anyone has been able to get this to work and if they can offer any pointers?
I downloaded the Axis Camera SDK and have tried to fill in all of the connection fields as much as possible by going through each connection item and looking up the definition in the SDK help document but still cannot get the video to show in the control.
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
116
I have HMI MP277 10" Touch and need to connect it with a S7-300 PLC on Profibus NETWORK - I am using TIA Portal V13 and tried to use the Device...
1,027
Good Morning , and Happy Fathers Day , We have a lot of CEIA Metal Detectors and we would like to capture this data into our IPM Stations ...
1,234
I am currently using DVP14SS PLC with DOP-B HMI in which i want to read data from 2 scanners (Honeywell Scanner & Motorola Scanner). Communication...
3,831
OK fellas, I've been tasked with replacing a GE PLC with a MicroLogix 1400. The old program had a pass/fail setup written with some math...
2,468
