EasyView and EasyBuilder 500
Tharon
Jan 2007
Other
1,430
I have a machine with an EasyView 500, part number MT510SV2.
I downloaded EasyBuilder 500 from the Weintek website, and an EasyView 500 user guide, along with an Easy Builder "Getting Started" manual.
Searching through it all I cannot find anything showing me the pinout of the RS232 cable required to communicate from the HMI to a PC. Where can I find this piece of information?
I think I may have found it. In an Easybuilder 4200 manual, it shows the pinout for the MT5-PC cable (which the 500 manual says is needed).
http://www.ctc-control.com/customer/downloads/ctcview/EasyBuilder4200.pdf
It shows:
Pin 2 PC -> Pin 7 HMI
Pin 3 PC -> Pin 8 HMI
Pin 5 PC -> Pin 5 HMI
Not your standard cable, it seems the HMI Pins 1 through 4 are set aside to be able to communicate to a PLC on RS485 at the same time you connect with a PC on the RS232 portion.
hi all, i have an Easyview MT-500 OP which i'm programming with Easybuilder 2.6, this OP is connected to an SLC5/05 using DF1 i have trouble...
2,432
HMI (MT506TV) died on legacy machine in our plant. We have some SW back up and we have found another panel in spares, but i dont have software...
1,679
How can i upload project from EasyView 500 for editing purpose. i can upload the eob file by Easy Manager but it is not possible to edit...
3,523
hi how to upload easyview weintek hmi program . i tried usb to upload but fail.:banghead::banghead:
12,421
Hi, I have touch panel type WISECON EASYVIEW MT506TV-W. at the moment this type is DEFECT, the supplier give new type MT506TV-46W. Does any one...
2,255
