Problem with my Siemens SIMATIC S7-300, CPU 315-2 DP
ayekami
Sep 2011
Dubai
Hi Guys,
I am facing a problem with my Siemens Simatic S7-300,CPU 315-2 DP( 6ES7315-2AF03-0AB0 ).That is in the morning i dont know why but it went into stop mode and when we tried to diagnose on Simatic Manager it was showing i/o error.Can anyone tell what does that means.Just a note that we replaced the CPU with a new one just 2 weeks back so i highly doubt that CPU is faulty because for 2 weeks it was working absolutely fine.
Appreciate if someone can give an expert advice on it.
Export and post the entire diagnostics buffer.
Also, inform a bit more about the HW configuration of the system. Post a screenshot of the HW Config.
Dear sir,
I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8
The problem Im using MPI communication cable then upload the program station to PG checked CPU 315-2 DP showing ok but S7 program --> Blocks inside blocks not found then Upload from PC saved program not any error coming but my HMI not Ready so i am copy the project in the RAM to ROM but it does not to copy and coming the error [(8301)] insufficient memory space or work memory on the module, or specified storage medium not accessible and 2nd No reply to step 7 message frame (33:16418) error coming. sir can you help me how to resolved this problem
Sir My PLC and HMI are both together and the recipe is not showing in HMI
Repeat:
[..]Post a screenshot of the HW Config.
The PLC is an old type 315-2DP with the MC card and battery.
Is there an MC card in the CPU ?
Post a screenshot of the blocks that were uploaded. If there are only OB1 and SFBs and SFCs, then the program has been lost.
Hello, Today I install Siemens PLC software SIMATIC Step7 v5.4. after installed, I start SIMATIC manager. it pop up "Run-time error 35600, index...
10,163
I am facing a problem with a siemens s5 system, the topology of which is attached. This PLC basically controls are drawline and has two buses...
3,976
Ciao guys, I'm not used to program on Siemens PLCs, but sometimes I have to. I'm experiencing a strange problem when I try to connect to a PLC...
3,861
Hi, Im working on adding multilanguage to my project. When using a button to change language I get "invalid value 0 in parameter xxx". The zero...
1,023
Good morning Please i need an advise, I have a s5 135u cpu system , it is installed on printing machine. Nowadays its stop about 10 times in 8...
27
4,250
