intouch view app object deploment
RY_Guthrie
Nov 2011
Las vegas, NV
263
I am a newbie to deploying an archestra ide intouch view app object, what I am having problems with is after I make a new instance of it I am sure what do do next do I have to assign it to a node on my network using the assign tab and if so is that its name, ip address, galaxy name, the archestra itergration doesnt explain this very well. Is there a better document out there that gives a better explanation?
yes I have, I went through my manual from that class and have gotten quite a bit farther along, I got to were I am deploying now, just trying to make sure I am deploying the right derived instances and to the right node.
I have gotten it deploy but I am not seeing it in my application manager of my target node, under node properties of my target node local working directory, I am making the assumption that is where my gr is should be sending it to, but I dont see where I set that when I am ready to deploy. it asks which computer on my network when I set up winplatform underer network address but not for a path, kinda confused about that, any ideas? Thanks
1st question about the target node ...
Does it have a platform and engine deployed to it?
Yes it does, and I can connect to the galaxy on my development computer so I know they can communicate, I think the problem is on when I do the set up of my win platform for deployment, I use the discover tab to find my target node but that is where I lose my understanding, does it have a default directory it sends the deployed objects to? Or am I supposed to tell it a path? Also on the bottom half of the win platform deploy set up page there is a spot for a secondary ip address, whatis that for? I was wondering if you could possibly send me a screen shot of a fuctioning winplatform deploy page if you haveone handy, I know I am asking a lot but I am determinded to crack this nut!
ok when I try tp deploy I get an error, failed to deploy winplatform_trainingvis: platform start up failed. I got to looking I dont have boot strap installed on my target computer, is that part of intouch, sql or a completely separate software pkg, I know I am showing my ignorance again, sorry!
on my development node I can see the platform I want to deploy to target nodes, but on the target nodes I cannot see it under platform manager, and i get the message platform manager functionality disabled, trying to figure out how to enable it now. I do have bootstrap installed.
I made sure I had boot strap installed and to make sure I reinstalled application manager ver 3.1 sp3 running intouch ver 10.1 sp3. I am getting the message when I try to deploy is the failed to deploy winplatform_trainingvis: platform start up failed. and on my target node under smc platform manager of course my deployed node doesn't show up and I get the message platform manager functionality disabled, that is where I think my trouble is, the platform manager being disabled and I am not seeing how to enable it at the moment but I am reading over the platform users guide and application manager server users guide. My 2 best friends lately!
Hello, I am working on a project under Schneider M580, We have an existing supervision PC station develloped with Wonderware Intouch. The...
949
Has anyone experienced Intouch Machine Edition 8.1SP5 (basically Indusoft Web Studio) freeze all values on all screens when running CEview on a...
1,588
Is there any way to view live tag data with InTouch 10.1? I know you can do it with Archestra IDE with the "watch" window, but I don't see a way...
4,695
Can anyone say me how can i communicate Factory Talk View SE with Wonderware InTouch without using RsLinx.
4,935
I'm kind of new at all of this PLC stuff....but I am currently upgrading a Windows 2000 machine (Panel view - Siemens) to InTouch 8.0 and Softnet...
5,430
