archestra remote access
RY_Guthrie
Nov 2011
Las vegas, NV
263
I am using wonder ware 10.1 and application server 3.1 and when I try to access a remote gr node I get the error "could not access file repository share on gr node" I am not finding anything about that on any documentation, anybody seen that before?
I've experienced this before, it was the domain.
Check to make sure that the domain is not your local box.
Other than that experience, I don't have more information.
So I made some changes to our plants WindowMaker application and I'm having trouble deploying the update to the live runtime. From the deployment...
128
Dear All, We are designing a solution with 1756-L74 and Archestra. We need to use SOE to show on HMI. Please mention any solution if someone did...
135
So I'm trying to enable history for a tag that is being used to display PPH on InTouch. I was able to locate the tagPath by finding the display...
687
Got myself into a bit of a jam this AM. Somehow the graphic editor hiccupped and when I went back into my graphic, everything was gone. I...
1,065
It's a while since I had used this that I forget where the setting to enable/disable object security is. There are some devices (pumps/valves)...
857
