filename.ach c600 panel
George Graziano
Jul 2004
NY
447
I am trying to look up info on a C600 panel from Rockwell. What I can find on it says you can hook up directly to it and the system has programming software built in. Or, you can use CC Workbench offline. I found a file (filename.ach) and assume that is it. But the software tells me, Incompatible project version encountered. Please upgrade. But, I downloaded right from Rockwell websight. Also, the software is looking for Filename.ccwsh
George
The screen file is .cch by memory
The other files your are looking for is for the 800 series PLCs
You can access the HMI via a web browser. And an E/net lead
Of the top of my head. 192.168.0.1
But that depends on the system setup
Filename is *.CHA
There are 3 ways to program these, online with a browser
Using Panel view component design station or
with Connected components Workbench software.
What version are you trying to use?
Marc
Connected Components workbench version 6.01 This time I found an old thread about impporting it, not trying to open it. That allowed me to Import, then open, but now I get,
Opening application failed.
George
these three file extensions are needed
for all who need the reference
GMP_DOOR is a file name for that project
Ian,
I searched all the files they sent. Those files were not in there. I will have to wait until the end of the month when the machine gets in our plant.
Thanks Again,
George
I have an unusual task with a PanelView Plus 7 (running v11 firmware) and a CompactLogix. The customer wants to place a version number string in...
611
Does anyone know if it is possible to retrieve my .mer filename out of the PanelView? I tried looking through the ActiveX controls but am having...
1,904
I made changes on a display screen. I tested it on the server that has RSView32 Works on it. My question now is, I can't seem to find how to save...
1,707
I have a panelview 1250 that I'm using for a platform. These have been in use for a while. I'm replacing one, but for some reason the filename...
2,316
I contacted Hach and bought a kit they recommended for a customer to add Modbus TCP capability to his Chlorine Analyzer with a SC4500 controller...
218
