Hi guys.
I've recently been given an area that contains ethernet/controlnet and devicenet all with their own relevant setups.
Unfortunately each time navigate online using rslogix 5000 and disconnect get the message rsnetworx file not found (as it's not save on my works laptop so offline filepath differs).
I have done an upload through rsnetworx of the scanners, but noticed comparing to an original file some of the nodes have not been transferred fully across in the upload in the configuration? (such as an encoder for e.g.)
Is there a procedure you recommend when going online via rsnetworx to create a proper upload and backup of the configuration, that if a scanner fails we can simply download along into the new unit?
