FBC and FAL instruction in Studio 5000 with PanelView Standard
Frinehart
Jul 2018
Ohio
21
Good afternoon all,
I am attempting to get a panelview standard 1000e too communicate completely with a 1756-L83E through a 1756-DHRIO card and parts of the panel is communicating correctly with the block transfer. I've checked with hmi program to no avail and I have also tried to convert the block transfer bits to INT's from DINT's but it interferes with FBC and FAL instructions in the program. Sorry to ramble but my main question after consulting Knowledge-base is does anyone have input as to how to set up the FBC and FAL instructions? I feel as though this is what is in the way of complete communication. I have attached images of my studio 5000 program and the original PLC-5 program
Thank you very much
I'm not 100% sure what the FAL is doing (maybe something to do with sign extension?).
Anyway, the FAL destination and formula are using a tag named R_FAL_CTL_002_POS, rather than R_FAL_CTL[2].POS. I don't see where the .._002_POS tag is getting a value assigned to it, unless it is an alias for the ..[2].POS tag. Probably want to check if it is aliased as implied by the FAL formula.
Logix 5000 v32 on 1769-L16ER I used the FBC instruction to scan an array of DINTs for true bits and it works but I found a thing that just...
78
Hi guys, having a few challenges with 90-30 and FBC BEM341 FIP bus controller. The goal is to be able to replace either the CPU 350 and or...
1,865
Hi, folks, how’s going? I have some questions about FBC in Logix5000, plz check attachments: 1, how dose .FD work? I read help manual, but cannot...
1,366
I have (2) L541 5/04 PLCs in the plant and up until 3 days ago they were fine. I replaced the battery in one of them and had to reload the...
1,915
I have found a piece of equipment where i work where the messages do not scroll if there are multiple messages at once. Other machines when there...
1,963
