GuardLogix Safety Programing (L72) - Dual Channel Inputs
kdcui
Dec 2007
USA
386
All,
I have a hopefully simple question regarding programming safety routines.
Say we have 2 EStop loops wired in parallel configured to be dual-channel inputs. They are wired to points 0 and 1 on a 1734-IB8S module.
In the module configuration, I set these inputs to be dual-channel equivalents with a discrepancy time of 250ms. They are powered from a power supply and are not connected to the pulse test outputs.
When I am using these Estop inputs in my Safety routine, do I need to use a DCS (Dual Channel Stop) instruction (or similar instruction) to monitor the inputs? Or am I safe just using both inputs in parallel since I have the IB8S module configured to already check for input discrepancy?
Basically, does one need to check for discrepancy in both the hardware configuration AND the software programming, or are instructions like DCS meant to be used when one is not able to do this in the input module?
Hey everyone, I have a problem that is the CROUT keeps faulting out with a "16#5003 20483 Feedback 1 and Feedback 2 turned ON (1) unexpectedly."...
1,292
I have been searching for more information regarding qualifying standard tags in a safety task and all I have found is a quick excerpt in one of...
1,271
Hi all, we have a 1768 compactlogix 5345s safety controller firmware 20.14. it is randomly giving a major fault and a minor fault. the minor...
1,407
Hi All, I've been using this processor that communicates with safety I/O (attached to 1734-AENT) over 1756-EN2T Ethernet card. The client now...
1,936
Hi all, We tried to setup the hardware onto a 10 slot rack as follows, PS Slot 0: 5580 controller Slot 1: Safety Partner Slot 2: Safe Inp Slot...
2,731
