Using 1783 NATR with Siemens S7 PLCs.
PreLC
Apr 2019
Mars
586
I have S7 Profinet PLCs with local IP addresses in my plant. Can I use the 1783-NATR to configure a 1:1 NAT to get to the plant network?
Regards,
-PreLC
Update, it works! I had to add these to the "custom rule" section under Configuration>Network Address Translation. Otherwise I didn't get a reply back.
80 was for the webinterface, 102 for Profinet.
tcp/udp 102
tcp/udp 80
Regards,
-PreLC
I am currently trying to do the same thing, could you go into a little for detail on how you got this to work? I do not see a custom rule in the NATR setup. Thanks
Can you please share pictures of your NAT table? I'll try to guide you the best I can.
Yes, that is what I wanted.
If you have these rules, and the PLC still isn't communicating, have you set up the gateway on your S7 NIC to be the local address of the NAT? Is your NAT's gateway set to your plant's gateway address?
After this, can you open wireshark and see what error messages you get while using your client software(TIA/S7manager/Ignition etc)? The error messages would have port numbers, which would be used to see which ports further need to be opened up.
Regards,
-PreLC
Fixed! thanks
Thanks for your post PreLC!!
I just made what you recommended (Customs rules) a set Gateway Siemens PLC as the same as NAT (private network), and it is working.
Thanks for your help. đź“š :D
No problem man! If you discover something cool in the future, make a post too!
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
24
50
71
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
150
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
61
