Mitsubishi Q series... configuring an analogue voltage input
Mas01
Oct 2020
Leicester, England
1,105
Hi, I've got a Q68AD-G card (8 channel).
I want to configure it for 0-10v analogue input.
I've enabled the channel by using Un\G0. Then I used the 'io assignment' switch setting to set my channel to range 0-10v. However, the value read at the PLC tops out at 5v (ie 5v gives a value of 4000) - further increases in voltage input have negligible effect. The channel gives me the same values if I set the 'switch settings' to 0-5v.
Is there some other place where I still need to configure the channel for 0-10v?
Thanks for the help. The final step to make the changes take effect was to cycle the PLC power. Once I'd done this it all worked as expected. 0v=0000, 10v=4000 on PLC.
I've got a Q68AD-G (Mitsubishi A/D card) and I'm trying to set up channel 6 as a 0-5V range. I've changed the SWITCH SETTINGS so that CH6 says...
1,530
Hi, I need to send a digital output to turn a water pump Inverter driver ON/OFF. To this end, I'm planning to use a Digital Output Module, i.e. it...
3,528
Hi, this code refers to a Mitsubishi Q68AD-G card. Ch 06 was previously a SPARE channel, but I want to use it as a 0-5vDC input (D33). To this...
2,554
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
26
