Help needed!!!
bazmc
Oct 2017
ireland
Hi Lads.
Complete newbie to plcs but I'm tring to learn. Can somebody let me know how would I design a ladder circuit for a bottle reject station if a bottle is found with no cap installed.
2 sensors looking at the bottle. cap sensor A detect bottle and sensor B looking down into the bottle if no cap presented . And sensor for reject, and a confirmation sensor that’s it’s rejected. If reject failed stops the line and 3 in a row it stops the line.
Need it on a fairly simple layout so I can start to learn from it. Using Tia portal V13
Nobody here is interested in doing your homework for you.
Start by making a complete list of the inputs available and the outputs you'll be controlling. Write a description of normal operation and then write a description of what should happen when your sensors detect the abnormal condition.
Also, show us what you've tried so far, what works and what doesn't.
If you're willing to do that you'll find people willing to help. Otherwise, you won't.
Steve Bailey has given you the best advice and here is some additional info.
This info is not for the software/PLC that you are using. If you have access to RSLogixPro there are 4 files/examples of Bottle line exercises located in the Downloads Section in the Allen Bradley folder.
Ive been googling worked out exercises examples so I can try to apply but can't find any. Ive just started plc's and ive seen a conveyor at work which does this and thought it might be easy but can't get my head around it. I'm not asking for my homework to be done but just that I could apply something that ive seen to understand it all easier. Ive picked up a siemens s7 1200 plc and using Tia portal v13 software
The questions you were asking were very similar to a classroom example. I have no training whatsoever in Siemens. If you think it will help, I can download the files I mentioned and print them to a .pdf document. I could then upload/attach them here to the thread.
Edit:
See attached files.
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
225
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
956
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
623
Hi all, I have got this machine that needs to be up and running soon. This machine has Schneider's Controller and I/O modules, 3 vfd's, 2...
905
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,081
