SCADA system with RS232 to a MPI connection in S7-300
Andoni
Jan 2005
Hi Everybody!
I want to make a SCADA system by means serial port RS232 connected to the MPI port of a S7 CPU313C-2DP. I will use the software LabView DSC Module 7.0, InTouch, WinCC Demo or LookOut 4.5 Demo. I already know that exist a HMI_Adapter from siemens which makes this connection, but:
* Is there any different way to do it without using this adapter?
* Can i use the PC/MPI cable adapter?
* Do somebody know how much does the HMI_Adapter cost?
* is it possible to use the USB port some how?
Thanks.
Andoni.
Hello andoni;
Siemens sells a USB to MPI adapter, part no. 6ES7972-0CB20-0XA0, that seems to work well.
For more information, do a search on this forum for the module, or ask your Siemens rep.
Hope this helps,
Daniel Chartier
Hi andoni,
Stick with the USB Adaptor as daniel says, I used to do some testing with wincc with an old PC Adaptor but its quite slow in comparison to the newer interfaces. Price wise i dont think theres much difference.
Regards
Steve
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
142
I am looking to put together a SCADA system using Automation Directs Productivity 2000 line. Figured id go that route versus going Allen Bradley...
185
We are looking at upgrading a very old system and I am looking for ideas on the best SCADA to try and implement. Need to be costly effective and...
3,077
Hello everyone, I have different AB controllers (Around 50) running at different area in Manufacturing plant. I want to create an ethernet...
20
3,389
I'm working with a client who are in the process of installing a smart waste solution in a new building. This solution will be using s7-1500 PLC...
4,709
