Powerflex 40 IP address
It makes sense because the timeout message command is every ten seconds and there are five seconds are being sent to N42:3. I changed the timeout time to 15 seconds and will try this again on Monday. Wish me luck.
Thank you all for your help.
Aaron
Success,
Thank you all for your help. I have the project working and I cannot thank you enough. Now I have another task to complete. I need to interface Panelview 300 mono, one powerflex 40 drive and SLC 503 processor. I need to find the cheapest way to do this. You help will be highly appreciated again. If I need to create seperate Thread for this topic please let me know.
Thank you
Aaron
Success,
Thank you
Aaron
I am glad to hear you got it working. I would start a new thread for this new topic.
Stu......
Hi guys, I'm having a similar problem to Dabanani. I need to change the IP address of a powerflex 40 but I don't have the 22-HIM, so I don't have the parameters screen facility. Is there another way to connect to the adaptor and change its address? It already has a static IP address, so BOOTP will have been disabled, it's not showing in BOOTP even with my PC plugged in to the same switch and set to same IP range. It responds to pinging, so there is some link established
In BOOTP/DHCP tool, add a relation with the drive's MAC and current IP address. Then click on the relation in the relation list, and then click Enable BOOTP/DHCP. When you see a BOOTP request from the drive, change your relation to the new IP address.
Thanks @RVaughan. We found another thread on here that said CCW could connect to powerflex and set IP config online. We tried that and it worked. But thanks for your time.
Good Afternoon , For the last couple of times I have had a hard time getting Rockware Software BootP , to see the MAC address on a 22-COMM-E...
18
4,477
Good Evening , I’m trying to get our maintenance staff to set the IP Address for a 22-Comm-E card for PowerFlex 40 drive . I usually use...
2,347
Good Morning , This morning we had a overreaction by our maintenance group. They replaced a bunch of 22-COMM -E cards , without setting IP...
2,182
Hello Experts, I am a newbie in setting up the Allen Bradley PowerFlex drives and need to assign an IP Address to a PowerFlex 523 series drive...
4,727
I have 1x SLC500 and 4x VFDs on Ethernet. I have a new PLC program to download with new IP address information built in. 1. Can I just change the...
5,169
