Hi everyone,
I have a small project where I need to use plc to get sensor data and log them to an sql server locally or remote.
I have found two library that helps to read tags from plc device which are as following:
- https://github.com/dmroeder/pylogix (PYTHON)
- https://github.com/msvargas/node-logix/blob/master/src/PLC.ts (JAVASCRIPT)
But for above libraries i need to have a middleman device/server to listen to plc tags and help store them to sql server. (I have used both libraries and both works and I can read the tags from plc)
And my question -> is it possible to configure PLC to direct write to sql without any middle man device to help us lower the cost.
PLC Model: Link
PLC Model: Link
