Msg instruction in compact logix
sreeragrsis
Jun 2022
India
Is it possible to configure the MSG instruction in CompactLogix to communicate with another CompactLogix in online mode or should the PLC be in Program mode...?
Actually, it is a running plant and this 2 CompactLogix need to communicate with each other
I am using Studio 5000 V32...
MSG instructions can be added online and in run mode, unlike Produce and Consume.
You should be fine.
I do a MSG Read only, this way when a search is performed on the tags, the MSG instruction is found, rather than MSG writing.
Basically set up a MSG read in each PLC, and I pass an incrementing value as heart beat. This accomplishes two things...
1 - You don't have to worry about someone putting the PLC you are reading in program mode and reading stale information.
2 - Heart Beat bits can produce false comm loss errors due to scan times, msg time...turns into a coin flip
I have two 1769-L32E Compact Logix PLC controllers. One the remote plc I have two msg instructions setup to read two separate ESD tags from the...
4,526
Dear all, i am using compact logix l18er and control logix l63 i want to use message instruction in between this to i am not getting proper...
3,802
55
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
335
Hello Friends I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP. Now, I am trying to...
266
