Any harm rolling a PanelBuilder32 project back to an earlier firmware rev?
strantor
Sep 2010
katy tx
401
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the back, it's a 2711-K5A8, Rev B, FRN 2.00.
I purchased a used 2711-K5A8, Rev B, FRN 2.00 from eBay, uploaded the project from the bum terminal, and when I went to download it into the "new" one, I got "Error (4005) - File is NOT compatible with terminal."
I checked the settings in the project I uploaded and it says "2711-K5A8 PV550 key, FRN 4.10-4.xx." So I suppose someone upgraded the firmware at some point or replaced a board inside, whatever board contains the firmware.
I changed the firmware setting in the project to "2711-K5A8 PV550 key, FRN 2.00-2.xx." and then I was able to download it to the "new" PV550. It seems to have worked, but I can't test it because the machine it goes to is in another state.
I'm wondering if it's safe to send this or if I need to upgrade the firmware and download the 4.10-4.xx program.
You might want to test it. Or send it to the customer to test.
I think there were new items added around v3.8x of PanelBuilder because I know if a project was created with v3.83 it can not be opened with v3.81.
Said that, if no new objects are used it might run fine.
Hi All I want communicate PLC S7 300 by pycharm and use Libnodave pass usb mpi Can do it? If can please guide me (exemple of script python) Thank...
1,952
Hello everyone, I have a strange problem that I hope someone could help me with. This is what I have done: I have 2x Windows XP VMWAREs...
2,861
Hello my friends, Would you please let me know how we do the IO addressing for DeltaV Charm? I mean, what do we use instead of Rack/Slot/Channel...
1,877
Hi guys, I have a stupid question, I used a lot of Math & Compare instruction (MUL, CPT, .. )in my PLC, will it harm or one day PLC will cause...
2,660
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
94
