Hi
This may be a simple operation ... but I just can not connect SLC505 (1747-L552) and PV550 (2711-T5A20L1).
I have absolutely no experience with Allen Bradley's Ethernet stuff.
I am using RS232 on SLC505 for programming. PV550 is connected to SLC505 with RJ45 (twisted pair).
It "seams" to work. ENET leds on both the SLC505 and
the PV550 are on (illuminated).
I have absolutely no clue how to configure SLC505 ...
Should I use BOOTP...or not?
If I don’t ... which IP, Mask, Gateway address I should use ...?
Do I need routing table defined ... ?
Should DHCP on PV550 be enabled or disabled?
What IP address should I assign?
I cant even download from PanelView to PV550, as I cant
seam to get the communication to work (RJ45 or RS232 printer ports?)
The most frequent error on PV550 I get is error # 16417 ...
Ok, it’s quite obvious I am "very" lost here.
Any help would be greatly appreciated (explanations, existing URLs etc)
Thank You
V
Thank You
V
