Communication between android and Micrologix 1100
pehegr
Sep 2015
Denmark
Hi
Are there anybody that have use a android phone app to set an input in a micrologix 1100 plc?
If yes does there be an easy way to connect the phone and the plc over ethernet/wifi. So the plc could see when the bottom in the app has been pressed.
I don't know how the plc could communicate with the phone
I’ve not played with this one (yet). I’ve used “SCADAMobile” but it (currently) only works with Apple OS. Now that I know about this one I’m going to have to play with it so I owe you a “thank you” (I wouldn’t have gone searching if you hadn’t posted this thread).
http://www.myscadatechnologies.com/
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
84
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
300
Communication between devices will stop working for a certain period of time. I caught the error message using WireShark. I cannot identify the...
100
I am having trouble running the application throught my PLC, tm221me32tk with magelis HMIGTO6310 I have prepared the plc programme, also created...
108
Hi, I am trying to send data register type (D) from Toyopuc PC10g to FX5u. Does it possible to connect both plc using fx5u features which is...
30,620
