OAT software
dandrade
Jan 2004
374
OAT Software
As Install the kernel to make the simulation?
It has members with avatar of these figures, that represents the software adds the nick here, to know who they are.
-----------------Portuguese------------------
OAT Software
Como instalar o kernel para executar a simulação?
Tem membros com avatar destas figuras, que representa o software adicione o nick aqui, para saber quem são.
Moin dandrate,
currently you need to install the OATs kernel on another PC (or PC104 or else) to run a PLC kernel which in turn executes the project your are testing.
This way you can develop complete PLC projects using the IEC 61131 programming languages.
A simulation and more debugging aids are under construction but not yet finished.
The parrot is a nice helper. E.g. it reminds you to save your work or it announces possible problems with your network IP address. BTW, if you don't like Peedy, you can switch it off.
Hope this helps.
regards
Friedrich
Thankfuled.Then it is equal connect to a PLC. Would stay like the figure. It connects both PC by cable serial.
Software BEST! !!! One question, you go posssible, or upgrade add "Drivers" will go programmer PLC real? You plan the atualization.
Have install AOT software is run. Sometime not simulate, what the enable? Files change kernel (in boot)and freezy, not change Win. Help members...
1,918
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
428
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
168
Hi. This is pretty basic but I'm struggling to find an efficient solution. I have a float value of let say 666.555 that I want to move / split...
210
Hi Everyone, We are EDAC Electronics Australia and we provide wireless automation solutions and I/O distribution products, with expertise in...
772
