Omron Temperature Control Module
fredjohns
Dec 2008
Pennsylvania
119
Does anyone know where I can get documentation on a module for out Omron PLC. The module is:
Temperature Control Unit
Omron
CQM1-TC001
Fred Johns
Fred,
The W396 manual is for the CJ1W Temperature Controller Modules.
You may need to register on the Omron247.com website to download the manuals.
Another option is to go to www.omron.ca (Canada).
From the menu on the left choose Support, then Document Library.
When the page loads, in the bottom box for Partial Document Number enter W238, then Go. It should pull up a link to the manual in pdf format.
Hope this will help.
Hello, I am trying to write a program for a freezer system. I have a CP1E with TS101 expansion for testing, but the actual project will use...
2,148
Hello. I have an NJ101-9000 with NX I/O. I am trying to create a recipe for heat treatment, using ramp and soak times. Has anyone here done that...
7,202
hi all, hope some of you omron guys may be able to point me in the right direction regards addressing and temp control cards. the task is...
3,090
CAUTION: This will be a long post. Please give me some light, I am so lost with the omron temperature controller that we are using to...
3,435
Dear all, i have found a difficulty on communicating omron plc and omron temperature contoller. my plc model is CJ1W-PA205R comunication card is...
1,560
