I am new to PLC programming. I am using a ControlLogix processor with the RSLogix 5000 software. I have a station that has a water tank 0-100% full. There are six discharge pumps. I need to program the discharge pumps to come on at certain tank levels. The pumps need to rotate in the start sequence i.e.
First Start 1, 2, 3, 4, 5, 6
Next Start 2, 3, 4, 5, 6, 1
Next 3, 4, 5, 6, 1, 2
etc
But also only a certain number of pumps need to run based on the tank level so lets say...
Tank Level = 20% Run only 1 pump
Tank Level = 40% Run only 2 pumps
Tank Level = 50% Run only 3 pumps
Tank Level = 60% Run only 4 pumps
Tank Level = 80% Run only 5 pumps
Tank Level = 90% Run only 6 pumps
So there is a rotation between the pumps that are needed to run. Also, each pump has to be checked to see if it is in Auto mode and if it is not then it should be skipped and not be part of the sequence.
I hope this makes sense. I have to idea how to accomplish this but I am sure it has been done before lol. I appreciate any help that can be provided.
etc
