connecting a vfd with S7-312 cpu
AMER LAMBAZ
May 2012
riyadh
hello all
i have aproblem with connecting a vfd to a plc
the project is solar hot water supply
this project having a solar pump operation for switching on and switching off the solar pump .
the main issue is i want to connect the vfd with plc i konw that i should use :
Digtal Output to command the vfd to run/ stop
Analog Output to command the vfd speed
Analog Input for the vfd speed feed back signal to plc
Digtal Input as Run/Stop command to plc
Digtal Input as feed back from the vfd for Run/Fault status
but i didnt know the wiring arrangment and still having problem with scalling function in s7 312 cpu program
and iam using the TIA PORTAL V11
i will be thankfull for any suggestion
If you don't have the manual and the wiring diagram for the VFD, you must not touch it! What make/type of VFD is it?
When you get the manual, start with testing the start signal, speed SP and feedbacks directly on the VFD terminals without using the PLC.
When this works, come back for PLC connections advices.
Kalle
So most of us know that it can damage a drive if you disconnect the motor from it while the drive is running. This came up again today and I...
1,966
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
26
79
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
88
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
226
