DC coils have a predictable mechanical force because the field strength is a function of the applied voltage and the resistance of the coil winding. AC coils rely on the impedance of the circuit, which varies with the stroke length. So if something hangs up the armature on an AC coil, the current increases and the magnetic force does along with it.
In a force guided relay, you are "guaranteeing" that if a contact welds, the other contacts in the relay cannot possibly change state, because the force it would take to overcome the welded contact is not there. The predictable pulling force of the DC coils then allows that "guarantee". With AC coils, the coil would start working harder and may break the shaft on the welded contact, allowing the other contacts to change state.
