Honeywell Control builder Sychronization on redundant servers
asim_rana
May 2005
50
  1. We are using honey well DCS.our system topology is we had redundant processors c200 & then Remote I/O cards.Uplink & Downlink both is on Controlnet.For viewing & control we have redundant dell servers & 3 dell workstations.Every thing is fine at low level i mean when primary Dell server goes down then Backup automatically becomes primary & dell stations dont have any affet .They start taking Data through New Primary server as we had made 4 sation.ini files.Any change which we make on display builder through any primary sever is automatically copied to backupserver as well.
But control builder files are not available.Files on primary are not shifted to backup when primary goes down.Even when i go to station software & synchrozied both servers every thing else control builder files is available to backup.
When i go to station software then to file replication status is as under.
Abstract
Mapping
above three replications are ok
I dont know how to replicate controlbuilder files
2. When primary dell server goes down its station softwatre quits.i had move two linces of station softwares for both servers through quick bulider & assign different station no's to both stations for redundant servers. But in the server running on primary is possible to open station software.Is it possible to run station software on both primary & backup redundant servers.
Any one ,help me in detail
Thanks in advance
Post IconsYou may choose an icon for your message from the following list:
No icon
1. ControlBuilder database (ERDB) don't replicated using file replication util. You need using Honeywell Engineering Tools "DB Admin" tool. It windows mmc console application what you can find on the servers.
2. Do you use Honeywell FTE network driver?
Hello Expert, I'm now with Honeywell Products. Can some one advise which connection setting to be used during HMI development using HCi Designer...
1,542
Hello, friends. I've programmed a ControlEdge 900 PLC (900CP1-0200) and I now have to make an HMI application for a 900 Control Station...
2,039
I am trying to use complex code to make a button blink. I need to OR two digital variables. I can’t find information anywhere on the syntax or any...
2,054
Hello, Without using the Honeywell 900 Control Station starter file, how can you create a button to export all your log files onto a USB stick...
1,722
I am new to HCD (ver 4.403), but I have a problem programming the controller time on my HC900 C50 controller (4.4 FIRMWARE). The controllers time...
3,755
