Have you seen any Small Din Rail UPS units on the market
Rob S.
Sep 2008
Maryland
739
I have some small devices that I would like to put UPS units
on,that are in small panels. These devices are wired direct,
so a UPS with Receps are more trouble. Have you seen any small
din rail UPS units anywhere , maybe 24 vdc, direct wired to
terminals.
Thanks, and have a good weekend.
Hello Rob;
This link will take you to a number of Siemens Sitop DC UPS units; 24 V DC input, various DC outputs. They are DIN-rail mount, control panel dedicated units.
Use the links on the part numbers to open different webpages for the different units; look at the description tabs in these pages for more information on the different units.
Hope this helps,
Daniel Chartier
Thanks DChartier for the response ,
I looked at the the Siemens Sitop units. When they mean "Mains Buffering" does that mean if we lose power to a device that is drawing 6 amps, with a 3.2Ah battery module fully charged, the Sitop UPS would
last for 10 min. without incoming 24 vdc.
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
709
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
329
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
1,339
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,137
Anyone know what the little green triangle on SCREEN 3 means ? See picture Thanks
456
