On startup look for a white square in the corner press and hold it you should get to the configuration mode
From the PanelView Plus Configuration screen, you must first Load the program you wish to start automatically. Then go to the Start Up options. "Run Application at Startup" should already be selected but you must press OK at this screen. Reset the terminal.
