Theoretical question for career.
AivisNewBie
Mar 2018
None
Hello all,
I have just finished my bachelor studies and looking for a job.
One of my lecturer suggested me a job in which I should create DCS systems (know a very little of them but I know that these are really huge projects for which I have no training). I only had some experience with simple projects (I programmed PLCS created HMIs)
Lets say I will be offered a job (probably not, but who knows). They would provide training for it (I hope so).
Question:
Would I be able to Create/Service DCS systems with the training and my current experience, or firstly I should get some more experience with simpler jobs like SCADA/PLC/HMI and then move to the DCS systems.
You will crash and burn, at first. When that happens, get back up and try again. It doesn't get easier, you just get better at it. A mentor is priceless.
Is this a company looking to hire someone, or a piece of work you do to display your skills?
See it from the company's perspective. You just left University, why would they need to train you? This doesn't mean they won't, but it may also mean that they give you the facilities to learn by yourself instead.
Further down in your career, once you have knowledge in a specific field companies will pay to maintain that knowledge up to date (when it comes with certifications or knowledge and application of standards) or to retrain you to continue your job and take on new responsibilities.
Fresh out of University... I don't think that will be a given. Also, because you will most likely not be expected to take on jobs by yourself, particularly in a DCS type system.
Question:
What would the DCS be controlling? I can make control systems for a lot of things, but am not doing it. Why? I have no clue what I would be making a system to control with.
+1
You will never find a first job that you are totally prepared to perform. That includes "Do you want fries with that?" level. It is impossible to not have mistakes. What is important is learning how to correct them.
Jobs and skills
I once (and so far only once) had ALL of the skills that were posted for a job. After I applied for the job, the person doing the hiring told me that they were prepared to pay half of what I was making in the job I had. That was a bit disappointing!
So even if you do have all of the skills that are listed for a job, they may not want to pay you what you feel those skills are worth.
Set yourself up to make mistakes in the safest environment that you can, ideally in a lab. Test your code as much as you can. Then work out the rest of the mistakes after it gets installed. And learn how to do it better next time.
Hello all,
Question:
"Create DCS systems" is a broad subject. You could be one of the back office guys that actually designs the system, you could be a field engineer that installs and supports the system, you could be the guy that creates the interface screens, etc, etc. Depending on your location the options may be limited as well unless you are willing to relocate, unless you become a field engineer in which case you live out of a suitcase and it doesn't matter where "home" is.
Also, the terms DCS, SCADA, PLC are all semantics if you ask me. They are all various forms of process control. If you can program a PLC you can program a DCS. The important part is knowing the process you are controlling, and knowing the system you are working with, and knowing its limitations and nuances.
If you want to look into DCS, look into GE (MkV, MkVI, MkVIe, still some MkIV out there), Emerson (Ovation, DeltaV, etc), Siemens (T3000, TXP/T2000, etc) Alstom (Blueline but that was purchased by GE and is being supported but no new installations) ABB (Bailey... a dinosaur but still supported). They are all very different in terms of how you program and interface with them, but ultimately they all do the same thing, just like a PLC but on steroids. For that matter I've built PLC systems that are more like DCS systems, using GE RX3i with remote Versamax IO drops "distributed" all over the facility.
Ok guys, this is another theoretical description of PID control algorithm and also one attempt to explain why PID blocks (for example FB 41...
11,620
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
165
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
68
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
91
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
80
