aiki202
Can someone please explain where the parameters for a VFD, for example a PowerFlex 525, are saved when you use Studio 5000 Logix Designer through the I/O tree and open an instance of Drive Executive from the Drive tab?
You can see and edit all parameters and of course perform an Upload. Where is this data actually saved? I would assume it is embedded in the .ACD file because no other files appear to be generated?
If I Upload the parameters in this way and the VFD fails I would also assume you can perform a download of the parameters to the replacement VFD?
