Connecting profinet device over EL6632 profinet controller (beckhoff)
Dusan_QC
Jan 2020
Belgrade
Hello everybody,
Could you help me to connect profinet device over EL6632 profinet controller in the TwinCAT 3?
I try to do that and I receive an error (see attached picture).
If somebody has experience with hardware configuration, please describe me briefly in steps on how to do that.
Thank you in advance.
Can you show how does your hardware configuration looks now?
With right click on devices and "Add new item.." you should be able to choose Profinet device (EL6632). Then you click again on your Device (EL6632) and "Add new item.." here you can choose the device you want to connect over your profinet controller - you need to integrate GSDML file probably. if your device is not Beckhoff).
Hello all, I'm working with an s7-1200 and a stepper motor in Tia portal v17. This stepper motor is an SMD23E2 and I am attempting to connect...
19
2,842
Hi, I have a question about the use of router or other system to connect a profinet network with the company's network. Simply explained: I have...
3,560
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
38
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
181
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
134
