Kinetix 6000 - all 7 Servos Motor want to run hi speed.Cannot slow down.Virtual Axis?
Aug 2016
Virginia
343
Good Afternoon ,
I have a machine that has 7 - Kinetix 6000 servos on it . All the servos want to run high speed and cannot slow down. They are all being controlled by the virtual axis . That virtual Axis is in software , correct ? Do you think the virtual Axis could act up ?
Could you also explain the virtual Axis ?
Thanks so much
You will have to explain in more detail.
Is this a machine you are troubleshooting, or one you are starting up for the first time ?
In general, a Kinetix 6000 servo axis is not "controlled by" a ControlLogix virtual axis. It can interact with a virtual axis via Gearing or Cam instructions, but it has its own control loop and associated axis objects.
Because a virtual axis by definition has no mass and infinite power, it's easy to inadvertently program one that moves too fast for a physical axis to follow. If that's what's going on, you need to examine the commands and parameters you are using the control the virtual axis.
Howdy guys - Looking for some insight on the MAM instruction. Had an interesting one today: I performed a controller upgrade on an older system...
436
Hello everyone: I am looking at the possibility of migrating Kinetix 6000 to Kinetix 5700(460V 3 phase). Reviewing the drive catalog, I have the...
1,128
We have two similar pieces of equipment, one of them uses a Kinetix 6000 for an axis and the other uses a Kinetix 350. When power is removed...
841
Hello All I have a machine built in 2013 but never commissioned. I have it almost complete. It has 2 Kinetix 6000's with a CompactLogix L43 with...
1,197
Trying to configure the 2nd drive on this machine. It is being difficult. I have the gains speed encoder data all with good data. when I try to...
1,835
