backendcode
Hello Experts,
I have a question, I am programming AB HMI and i assigned an IP address yesterday, but when I came to work this morning and grabbed my HMI to work on it, there was no IP address to my HMI.
That's how I assigned the IP address
Terminal setting --> Networks and communications -->Network connections -->Network adapters --> Ip address --> Use DHCP (NO) and then put my terminal an IP address, subnet Mask and gateway, pressed OK, got message about about reset the device to have the new settings tale effects so I did that.
Here is the pic,
https://ibb.co/k7erwz
Any idea why panel view couldn't hold the IP address?
But when I go back to terminal setting to assign the IP address, I can see the IP address there but can't see on main setting screen (As you can see in pic above) and I can't even ping the device.
Thank you for the help,
Regards,
Here is the pic,
Regards,
