cardmaster24
- Join Date
- Dec 2004
- Posts
- 2
Hello i am new here and have a question regarding pid control loops.
I am currently working on a project for my company which uses a unitronics vision 280 with E2B and 2 expansion modules for analog in and out. The project involves a liquid helium heater which has a temperature sensor on it. The temperature sensor is first directed to a shinko unit which uses a setpoint. The output signal from the shinko is then directed to the analog input module. On the plc it must be possible to change the setpoint and minimum and maximum temperature limits. This is done using MI. But when the system is running the pid loop does not work. I did read about pid loops and studied the example from unitronics but it does not work.
A picture of the settings i use on pid are shown below. What i see is that the control value stays the same and the output does not change.
Furthermore i also see that the heater is using the setpoint of the shinko instead of the setpoint from the plc. Meaning that a change in the shinko SP would also change the heater proces.
My question is if these settings are correct or if something is missing here. I also want to know if someone uses shinko's between a sensor and a plc and what his experience was.
