Studio 5000 Logix - CLX Rack I/O - Series and Version
AREDA
May 2023
UK
22
Hi All,
While building the offline project for CLX 5580 with 1756 Rack I/O, I noticed that there is a field for "Series" and "Version" for some of the modules, e.g. 1756-IB32.
Is the version reflecting the firmware, or is this a sub-level to the hardware Series?
And what happens if the module is to be replaced with another one from a different series (e.g. Series B instead of Series A)?
Thanks and regards,
A. Reda
Check out "electronic keying". It's set to "compatible" by default, which means that any module of the same type that's at least as new as what's shown in the project will work. You can also select "exact", which means everything has to match (even the serial number?) or "disabled". For most cases, compatible keying is sufficient. If you're concerned about spares going forward and you're not using any newer features, you can select an older version of the module than what you have and use compatible keying. That way, any replacement will work.
Ace! Thanks Joseph.
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
131
Hey Guys, I am looking for a cr@cked version of Studio 5000 Logix Emulator V28 or Rslogix5000 V21, which will work with my current emulator...
277
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
474
I have installed Studio 5000 Professional version V36 a time ago and installed today Logix Emulate V36. I have a exsisting PLC program, but...
726
Hi all, I'm going to start programming a 1756-L73 and I'm still waiting for the full Studio5000 to be able to start at it in earnest. But I...
432
