plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old June 27th, 2019, 05:47 AM   #1
Mihal33
Slovakia
Mihal33 is offline
RSNetWorks for DeviceNet via 1769-SDN with Schneider Altivar 340
Hello all,
I have a problem to set up correct configuration with Schneider Altivar 340 in RSNetWorks for DeviceNet, CPU is CompactLogix L33ER with DeviceNet modul 1769-SDN rev 4. I m always getting error 89 - tried to upload the ADR configuration and then download it again but it didnt helped. The Inputs and Outputs are mapped automaticly so I dont know where is the isue. The parameters of altivar can be uploaded or downloaded. If some had same issue and solved it pls help.
Thanks.
Mike
Old June 27th, 2019, 12:08 PM   #2
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Welcome to the PLCTalk forum community !
To explain: most A-B DeviceNet scanners have a feature called "Auto Device Reconfiguration", which will save device parameters in the Scanner.
If a device makes a connection and its parameter checksum does not match the Scanner's saved parameters, the Scanner will load all of those parameters into the device. This allows you to quickly configure a replacement programmable device without getting out RSNetworx or a user manual.
Error 89 indicates that the Scanner was not able to write all of the saved parameters into the device.
This is usually because the device's EDS file (which tells RSNetworx what parameters to attempt to save) was not correctly written. Often a device cannot have certain parameters written in a certain mode, or it will wrongly list read-only parameters in the ADR parameter set.
Because AC drives have a large number of parameters and third-party EDS files are often not well tested against Rockwell's software tools, I would just disable ADR for this drive.
If it's critical for you to have ADR working, then please examine the error message log in RSNetworx carefully, and post a link to the EDS file for the Altivar drive.
Old July 11th, 2019, 07:59 AM   #3
Mihal33
Slovakia
Mihal33 is offline
Hello Ken,
thank you for the quick response, I managed to get it work (Conf. assembly 20/70 or 21/71), but not with the communication configuration i wanted, first i used conf. Assembly (100/101) witch should required 8 bytes in and out, but there was the error 89. The auto idetification wasnt working correctly for this solution, because it automaticly was setting in and out parameter to 4 bytes witch is for the other two assembles. I ll try it later when i finish other project.
The EDS I used is from this page Schneider in EDS files v1.8
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1747 SDN to 1769 SDN Conversion bigLee LIVE PLC Questions And Answers 0 June 26th, 2018 07:35 AM
1769 SDN Devicenet Scanner Karim Halawa LIVE PLC Questions And Answers 3 April 10th, 2018 05:21 PM
Schneider Altivar VSD pbaker88 LIVE PLC Questions And Answers 2 December 15th, 2014 01:33 AM
1769 SDN Scanner Error Code 91 minaykha LIVE PLC Questions And Answers 4 January 27th, 2014 07:54 AM
RSNetworx and RSlinx cannot see DEvicenet scanner 1769 SDN jj4parker LIVE PLC Questions And Answers 11 January 22nd, 2013 10:15 AM
